something wrong with my truck?
Well, I don't mean to keep detracting from the original intent of this thread, but in response to you Dripley, yes those conditions are without the trailer.
As well, if the tire size is indeed my culprit, I still could not do anything about it. As I do not know what a smaller tire size would allow me to have for load capacity. I need all the weight handling capacity I can get due to the pin weight of the trailer. I do the best I can to counterbalance it, but I still have to have a minimum of 15% pin weight for stability.
Also, when I first bought this truck, the same tire size I have now is what I believe I was running when I first got the truck. So the MPG's have changed over the time of owning the truck when the tires have not.
Smaller tires. 235/85 R16 Load Range G's (3,750#) @ 110 PSI
Compared 265/75 R16's Load Range E's (3,415#) @ 80 PSI
Or... Standard 235/85 R16 Load Range E's (3,042#) @ 80 PSI
Food for thought.
I would have to get that G range tire...
Food for thought.
3,750 x 2 = 7,500# - 6084# = 1,416# Over
3,415 x 2 = 6,830# - 6084# = 746# Over
More food for thought.
I know my pin weight has put me over RAWR. By a couple hundred pounds... As well, I'm also trying to think about the dynamic loading. Cornering adds more weight to a tire and unloads the other. Going over bumps or dips can also add extra loading to the tires momentarily that increase the load.
I seen the last time I rotated my tires, my rims were rated at 3400lbs a piece. So, I'm up there, but gotta be careful...
What is your rear axle rated for?
