ok heres the case after my recent lift pump failure i have decided to save up an hopefully invest in i fass fuel system prob a fass 95 my question now is with this system my concerns are the pick up tube and stock filter housing does the kit come with the filter housing to vp big line also are these kits effictive with the factory pickup tube and stock filter housing or are they too restrictive to support the 600 hp they say the pump will support
Get a big line kit that goes in between the filter housing and VP44, it comes with the larger banjo bolts for the bottom of the filter hsg and the VP.
I ran a 150 FASS HPFP on my 02 for many years at 560 hp with just 3/8 line from the top of the tank to the filter head and not a single issue. just tied into the factory pickup tube on top of the tank.
UMMMMMM.....go to one of the vendors that advertise in the banners at the top of the screen here on this site like maybe Vulvan or DAP and simply click on the banner. Took 3 clicks to get to this from the Vulcan banner right on the top of the screen.http://www.vulcanperformance.com/category-s/182.htmBut wait there is another super easy option, let me show ya how.http://lmgtfy.com/?q=cummins+big+line+kit
Edited by Wild and Free
easy 600, I was at 560 hp through it alone as the only filter in the system other than the suction screen pre FASS with absolutely zero issues and still 15 psi at the VP44 at WOT while power pulling.
That with 3/8 line from the factory tank pickup to the factory filter with bigger banjo bolts and the 1/2 inch big line between the filter and VP44.
