- Replies 19
- Views 3k
mikeyg164 5 posts
mopartechnician 3 posts
mulcher812 2 posts
xtrooper89 2 posts
I have a 99 4wd auto, bone stock. The tranny doesn't want to shift out of first. I have replaced the output shaft speed sensor, the governor pressure sensor and transducer. I also replaced the ecm due to the delayed WTS light/fuel pump issue. I checked my alternator for AC noise using a snap on meter it it was 0.03 to 0.05. I've owned the truck for 4 months and it appears to have a fairly new alternator. I took the truck to a local tranny shop (long time biz) he hooked it up to a snap on solus scanner and we drove the truck for about 20 minutes. During that time he said the computer had the p1693 and he couldn't communicate with the body control module. My door chimes, power locks etc work...He then said he felt the PCM may be bad and suggested I borrow one from a friend to see. Problem is, I have the only auto...
Can you tell me where the body control module is and what your thoughts are on it..
I appreciate your time
Mike
Western KY
