MAP sensor
If you do need a sensor, I have a NIB sensor.
Personally, i'd Ohm it, then clean it, then ohm it and see if it needs replaced then.  It could just be full of crud.
Edited by CSM
What year is your truck?  if it is a 98-00 I will swap you sensors
And yes I had a map sensor stick open at 45psi.
02... Thanks for the offer though!
I see what I can do. Maybe magic will happen and it'll start working again
