- Replies 14
- Views 18.2k
Mopar1973Man 3 posts
Wild and Free 2 posts
angus 2 posts
williamsven 2 posts
Died while driving. Cranks, No start, No communication with any scanner. (tried 3 )
No gauges, No tach, No low beams as of a couple weeks ago..
Checked for power at PCM, - Pcm had 12 volts at the Two main PCM feed circuits.
We unplugged the fan clutch, disconnected the batteries, touched + & - together for ten minutes with the key on. Reconnected – no changes.
Checked every single fuse.
Added engine grounds, cleaned all positive terminals.
REMOVED, disassembled entire TIPM. Cleaned all TIPM contacts internally.
TIPM had no visible corrosion, No visible cracked solders, no visible cracked pathways. had a lot of dust, some oxidation on the main power wires, some oxidation on the terminals and where the boards make contact.
No changes. Still no com-no start. - no low beams.
I have fixed several older cars computers at board level, this ain't my first rodeo but it was my first dodge Gen 3 TIPM !
Checked grounds, clean.
No changes.
I may not have internet where im about to go work on it ,If someone knows and they can text me.. .210 six one four - one four for fore.
