DRIVE PRESSURE gauge & port location
- Replies 26
- Views 13.6k
AH64ID 6 posts
organicfarmer 6 posts
Mopar1973Man 5 posts
Wild and Free 4 posts
Time for a drive pressure gauge! I ordered a matching gauge [boost, 60psi] to the ones i have & bought some 1/4'' copper tubing & fittings to port into the manifold. the other end of the copper will attach to the poly boost tube that comes with the gauge.
Two things i'm not sure of,..... do i need a soot filter?? [ah62id], your turbo article in tdr dosnt show a filter,.. does that work ok? i'll prob. end up with a simular setup.........
The other thing, where is the ideal place to tap the manifold?
THANKS!!
