Just wondering what all i need, how long of pieces i need to do the crankcase vent mod in the article page for the 24 valve 2nd gen
  • Replies 63
  • Views 15.9k
    Lengths of 1/2" PVC pipe 20 1/2" 5" 24" 2 1/4" Length of 3/4" heater hose
  • Buzzinhalfdozen
    Buzzinhalfdozen
    If you have any questions about stiff old hoses, Wild and Free is the expert around here.....
  • Wild and Free
    Wild and Free
    I just added a chunk of old 5/8 garden hose to the existing hose with an adapter fitting and ran it into the frame rail hole next to the engine and back and exited it out the hole in the frame rail ne
Where I live with the mountain roads and offroad use. I've manage to spill over 1 full gallon engine oil right into the fan. I've managed to spill about 1/2 gallon panic stopping on the highway for deer. So the whole easy hang in the front will no solve the actual issue.
The best solution is to pull the 24V tappet cover and put a 12V cover on. Never worry again about it.
Tried that... blew out the tappet cover gasket. Most here aren't running 70psi of boost though so take that fwiw.
I have my front one extended down as well. I'd like to run it back to where the 12v cover dumps at some point. Also not the dang 12v covers like to leave at least 1 drop every time you stop!
21 hours ago, Mopar1973Man said:
I'm going to rebuild mine and I'll measure everything out and document it all over again. I just built one for a customer and it turned out perfect. The vent doesn't touch the upper radiator hose. Lined up nice and everything. I've got a few trick like how to get angles set right and glued right. You could build it out of copper and then have it chromed if you really don't like the plastic look.
Thanks Mike I think I will jump in and redo mine too, since I just put in a new radiator, got to keep it clean
Nice update there Mike! That's about as straight forward as you can get! When I was doing this last night, the first bit of pvc I got was 1/2in, didn't realize it was a 3/4in at the vent cover hole! :doh:
Glad that was added!
So I went to check my improvised tubing and was curious. How much smoke is too much? Or what is/should be expected out of this vent?
Simple test is called the tea kettle test. Start the engine and leave it idle. Now unscrew the oil cap and just place it in the hole. If there is too much blow by the cap will dance right out of the hole. Normal blow by it will just lay there. I've seen some where the owner went to unscrew the cap and it was shot out of his hand. That is serve blow by issues and the engine requires compression test and most likely rings.
Alright I think I'm good. Let the truck idle, unscrewed the oil cap and it just sat there, actually started to thread itself back again lol.
So a little white smoke at idle is no big deal then? Or at least as long as your oil cap first sky rocket off the engine cover?! Haha
That's pretty much what mine looks like. Like just enough so you know it's there, but you actually have to be looking for it.
Basically in a nutshell as long as the blow by isn't bad enough to blow the cap off the valve cover and it's not ejecting oil out the breather tube then just keep on driving. Enjoy!
Yea that's basically the plan! I just like knowing what to look for!
Are there any other ways to check for blow by?
The ultimate way is to do a compression test. Then you know exactly the health of each cylinder. Then there is the blow by manometer which will tell you the summation of all blow by and might not detect a bad cylinder. The tea kettle is the simple test. Then just looking to see if it blowing oil. Those are the methods I know...
Sweet thank you :thumb1: big help all of you!!!
48 minutes ago, Me78569 said:
Mine under the truck looks like this.
no pic? :think:
it was straight down then my pcv broke, so I rednecked it together over the top with some hose leading down to behind the axle.
