oil in coolant, no coolant in oil. bad cap, next test?
- Replies 23
- Views 22.2k
BobCat 11 posts
Wild and Free 3 posts
JAG1 3 posts
flagmanruss 1 post
Usually I search the Forum before asking, usually find the answer. Breaking protocol this time and asking first - small panic.
1995 12 valve 5 speed, 576k miles.
On the way home from work last night, noted temp guage a little higher than typical, not high but not where it sits normally.
This morning, found radiator cooland about 1-2" lower than filler neck, some oily-looking emulsion in it. Immediately thought "head gasket!"
Oil level on dipstick a little low - half quart or so, only ~1,500 miles since last oil change. No sign of coolant / bubbles on dipstick.
Pressure tested radiator, holds pressure. Radiator cap does not - it is bad.
Ashamed here... if it were 10-15 years ago my brain would be less rotten and I'd know what was wrong, or what the next test would be to do, or how to proceed.
Unfortunately the only thing I can think of is a cylinder leakdown test and I 1) dont have the gauges and 2) don't know how to do it on a diesel.
Maybe I should leave the cap off, start the engine, and look for bubbles in the coolant as it flows by the neck?
Any of y'all want to point me in the right direction?
Thanks in advance.
