BHAF connecting Tube
What size Tube or pipe do I need for connecting BHAF to the TURBO Boot?? I've been running it for years without one and just soft clamping it over the lip on the BHAF but now i don't think that such a good idea after my latest turbo compressor wheel issues.
Compressor wheel was pitted and DAMAGED BY WATER as was told to me by ATS.
Edited by rburks
  • Replies 8
  • Views 3k
I've got a piece of 4" exhaust pipe stuck in the neck of the BHAF. Then just soft clamped to the neck no different.
I tried & failed with a 4" 45* elbow.  I think the issue is the flange on the BHAF is "soft" & compressible.  What is needed is a firm stiffener (like Mike's exhaust pipe) to go inside so the clamp has something to compress against.  The draft (taper) on MY BHAF flange makes it hard to get a good clamp.
I note the OEM filter box flange has tabs to engage the turbo inlet boot.  Maybe a few screws through the parts would prevent any slip off.
i did the very same thing. Works great.
Mine are just clamped together and i can still take them out as one piece and they stay together. The 4' pipe is a good idea however.
try to put some hair spray on the bhaf lip. it will help the boot to stick to it!
Dare I ask, why you have hair spray lying around?
it made a little grippier surface or stickier . Help the boot not to slip.   spray on the lip where the boot connect, connect the boot and tighten the clamp!     Have no problem with mine.
