- Replies 24
- Views 6.3k
Mopar1973Man 9 posts
Vais01 5 posts
dripley 3 posts
CTcummins24V 3 posts
Ok. Everyone knows I just replaced my front two ABS sensors. Here is what happening now. Start up roll out slow speeds less than 40 MPH the ABS and BRAKE lights remains off. Once I exceed 40 MPH they pop back on. I can pull over shut off the truck start up again and start rolling out and the light reset again. Once over 40 MPH it trips again. My old sensors works fine but had been broken in the leads. I solder and shrink tube then a few times and always was able to get the light back out. As for the rear speed sensor it dead on with my Garmin GPS so I really doubt I got a bad rear sensor.
