- Replies 11
- Views 2.9k
WesHawkins 3 posts
dripley 2 posts
gh0stman 2 posts
Dieselfuture 1 post
Guys, I have a friend who has intrusted in me to fix his truck. It is a 2001 CTD. This truck use to start when you turned the key right away, hardly would crank over a half an engine revolution and start. Now it cranks two or three complete revolutions before it starts, usually after a hot restart. He lost the factory lift pump years ago and had the dealer install an intank lift pump. He had the injector pump fail shortly after that pump was replaced. I'm wondering what the lift pump pressure should be when the key is turn to run but engine not started. I have none at this time but it starts and has presure of about 7 to 8 psi when running. Should there be initial fuel pressure and go off after a few seconds? I know my FASS fuel pump on my truck initually gives fuel pressure then shuts off and starts up once engine starts. I'm not sure about a factory system.
Thanks, wes.
