Rough Start This Morning
- Replies 25
- Views 5.9k
Hawkez 6 posts
Me78569 4 posts
Mopar1973Man 3 posts
dripley 2 posts
I recently had the high idle enabled on my truck, as a matter of fact, I haven't driven the truck since I did that. I went out this morning to start it and it had a heck of a time firing. It would try to start, catch for just a second and then die. I cycled the grid heaters a couple of times, not sure if that helped. It finally did start and it ran like a pig. I've never seen, first hand, a truck run on 3 cyl, but I imagine this was it. It seemed like there was a miss, sounded awful. You should have seen my wife's face when I went back in the house. After about 10 seconds the idle changed in an instant and ran smooth; the RPMs ran up to around 1200ish (High idle?)
Before flashing the ECM, I have never had any rough starts like this in the cold, the temp this morning was only about 25*, never any issues starting in colder temps. Maybe cold fuel??
I am questioning why it was such a tough start. It shouldn't have started in 3 cyl because it was cold enough, right? It wasn't plugged in, I'm sure that would have helped. Any thoughts, or is this normal High Idle software activity?
