- Replies 36
- Views 8.2k
The_Hammer 7 posts
Mopar1973Man 5 posts
CSM 5 posts
Vais01 4 posts
So, why does most everybodies truck do that when we fool the coolant sensor? They are separate systems and could not be causal.
Everyone who can fool the coolant temp watches this happen. Dummy gauge. To the OP, if the sensor is in fact a pressure transducer and you could find the voltage range, in theory you could set u
I bet you a dollar it acts like the video I linked.
Is there a way to make the stock oil pressure gauge show the actual oil pressure instead of being a dummy gauge? Truck in question is a 96'.
