- Replies 52
- Views 13.9k
leathermaneod 26 posts
dripley 15 posts
The_Hammer 3 posts
eddielee 2 posts
I bypassed my safety switch 7 years or so ago. As long as you always remember you should be OK. All it take is once. I reached in thru the window one day and hit the starter not thinking. It was in re
Sounds to me like the pilot bearing is sticking. I wouldn't drive it too long the way it is either. You don't want it to tear up the input shaft.
fluid level is good. Now i need to drive it and test out some of this stuff you guys told me about.
Hi all,
I'm having a slight(hopefully) issue with my 01 2500. Since I bought the truck at 248,000 it's always been a little tricky to get into first and reverse. If you put it in first before going to reverse its easy but first can be a little tricky. Anyway I just hit 254,000 and second gear is getting a little hard to get into when I stop at a light/stop sign. However it's only hard if I let the clutch out then put it back in. For example I stop at a light, take out of gear and let clutch out. Then put clutch in and try to put it in second and sometimes it's really hard till I play with it a bit. Usually I can get it but it seems like it's getting worse quickly. If I keep the clutch in from the time I take it out of gear until the time i take off from the light it will go in fine. All other gears shift fine aside from fifth feeling a little weird sometimes. I replaced the fluid right after I bought it with OEM fluid and overfilled about half a qt. I didn't check the fluid yet but I will as soon as I get a chance. It also got colder recently, was down below zero for a day or so but the truck still does it even with weather a little warmer around 20's-30's. What does this indicate? Am I hurting it by continuing to drive it? Also as soon as I shut the truck off it will go into any gear fine
