- Replies 12
- Views 2.3k
Mopar1973Man 4 posts
bry1216 3 posts
dripley 1 post
Cowboy 1 post
Welcome FF. I too am working my way back from the moon at 362k. I dont think I have a second in me however. Just keep taking care like you have started and you will make it. This is a great place to h
I am not sure what a Drive Belt Adjust is?!?!?! I switched to Gates, because all my other belts would get tons of cracks. Gates does not crack, but it does create a metallic squeak as the belt g
Hi everybody,
I'm a new member here, but have been lurking for some time learning as much as I can. My first truck was a lifted 01 f350 with the 7.3 psd. It had an exhaust leak and possibly bad injectors, and was lifted way high with 38's. Not my style truck, and was more than I felt comfortable tackling myself (I was 20). I found an immaculate 02 cummins with 115k miles, totally unmolested with a paint matched canopy and bed rug. I was in love from the first time I saw it on craigslist. Went and bought it the next day with a small loan. Fast forward about 2 years today, still have it and love it. It now has 140k on the clock and I have done oil changes and fuel filter changes every 7k and 15k respectively. I added a edge jwa programmer and keep it on 2x3. Saving up for a new trans, but the stock is holding up fine. Also saving for a lift pump, but I've never seen fuel pressures below 10. Normally 14 when cruising. I also have a BHAF on the truck. Everything else stock. Zero blow from what I can see, but the crankcase vent bottle makes a mess...
So my question is, what maintenance should I do in the near future? Just ticked over 140k miles, and want to keep up on religious maintenence and drive this truck to the moon and back a couple times. Coolant flush, different changes, and transfer case lube changes are all on the list. Also need to delete the crankcase vent bottle, its making a mess. The truck just started making a little creak from the front end while turning low speed. I'll get under there with a grease gun tomorrow and lube up everything I can.
Any other suggestions for maintence?
