- Replies 40
- Views 12.1k
Me78569 16 posts
notlimah 9 posts
Royal Squire 4 posts
eddielee 3 posts
Don't feel bad guys neither my PC's or my tablet worked with the look up. Linux by default will not work with online PDF files. I did manage to add a plugin to work with PC's. Now my Android ta
thanks to this parts look up tool I solved 2 problems this weekend in one shot. I was looking into see if I had a fuel canister heater and what it actually was. So I looked up the diagram for the fuel
I agree, the links are a bit fugly but it doesn't like the iphone that's for sure. I'll check later to see if the bookmark function or open in tab function works on the ol iphone.
Hey guys, I wanted to give you a heads up that we have created a Part Number Lookup tool in the new Articles.
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/
You can find a couple of different years and configurations in the above link. You can open up the year / model needed and use the drop down menu to jump around or use the bookmarks tool on the main page to jump around. We will add more documents as we get them, but most parts should span the years we have.
Edited by Me78569
