- Replies 34
- Views 11.5k
								Mopar1973Man 12 posts
								Justin Spring 6 posts
								Me78569 4 posts
								tonyjsan 3 posts
								Just ordered my VP through Jacob at DAP. 2 gigantic thumbs up for that guy. spend bout half hr on the phone with him. Be definitely ordering parts from him again in the future.
								It is always a good idea to get your alternator tested from time to time as they are VERY prone to AC noise. As for the code, I would start by cleaning and using dielecttric grea
								Maybe in the early years when modules when being developed and the technology was new. Yeah there was several buggy units that could do damaged because we were nothing more than beta testers back then
Good evening guys!
I went to go start my truck this morning it was about -4*C and it just cranked and cranked and cranked. Plugged in a code reader and got the code P0253 and the tpyical overboost code from the edge comp. Once the codes cleared, i turned the key back off, waited a couple few minutes, then attempted to start the truck again, started right away like nothing happened. let it idle for a couple minutes then hit the exhaust brake and let it idle for about 10 minutes, then shut it off and carried on my day driving my other truck as i had to be at the airport to leave for work. Side note, it would have very seldomly like once a month if that for the past 3 or 4 months of random 5 second crank times when cold before it would start when it normally would fire within the first crank or two.
Now a little back ground on the truck. It has just shy of 426000km on it, i do not know the last time or if the vp has ever been replaced.
Has what i was told were 75hp DDP injectors, edge comp w/wire tap, Fass 150, Hx35/40. It has had these for the last 125000km that i have owned the truck, and the wire taped edge comp and the fass 150 even longer, id do a rough guess of at least an extra 80000 to 100000km ontop of the 125000 i have put on it.
And from what i have searched so far and continue to search, but i have found either useless threads, or mixed opinions/facts that contradict other threads that i have read and that have more than one code pertaining to the VP.
I guess what i am asking is, has my VP finally crapped the bed, or very early signs of it going on its way out?
Thanks in advance for any opinions/advice.
Edit: Fuel pressure is a steady 15 to16 psi idle/light cruise, with the comp off, it is 13-14 WOT and with the comp on it ranges from 11 to 13 psi WOT depending on what setting it is on. It has never bucked or surged with it either on or off. I also run about 1oz/gal 2 stroke/diesel mix for the last 23000km steady and before that it was every other tank because i would forget to add and be already down 1/3 tank by time i remembered haha.
Edited by Justin Spring
