- Replies 38
- Views 8.6k
Jbolduc 20 posts
Mopar1973Man 5 posts
Dynamic 4 posts
Me78569 3 posts
Sorry it has taken so long to respond here. I've had a HUGE project in the shop that is finally coming to an end, so I can come out of the "cave", so-to-speak... It really depends upon how built
I just reread your original post, this time including the last paragraph about you talking to Lavon (which I had somehow glossed over the first time...). Everything that Lavon said is exactly what I w
You know the state I'm in says that I have to have insurance that covers bad workmanship. It also covers anything that I don't make right with a warrantee, in other words the insurance or the bond (wh
So I bought a "built" transmission last spring and have pretty much had problems with it since I picked it up, when I got around to putting it in and took it for a test drive all I had was 2nd and 3rd and manual 1st. The trans builder thought it was a bad pressure sensor but come to find out he had built it for a 99 and I have a 2002 so it had the wrong vb wiring. I also noticed that this "built" transmissions band was so out of adjustment I could put my entire finger under the apply lever which was also still stock along with the old used accumulator piston that was just floating around in there with no spring behind it. Well I ended up having the builder come out and re-adjust the band and change the vb wiring and haven't had a problem since.........until my move to Idaho.
when we moved to Idaho from Kansas I was pulling an 8x12 uhaul and was doing fine until I got to Idaho. I went to get on it when pulling out into traffic one day and the rpms went up the whole truck vibrated and I really didn't go that much faster. Now I have a 1-2 shuttle shift under light throttle, I back out of the drive way first thing in the morning just fine but put it in drive and acts like its in neutral then kicks into gear, has second gear starts sometimes and sometimes I have to manually put it in first at stop lights
I also talked to the trans builder and they said they would warranty it but I have to pull it out of my truck and send it to them to be serviced. I talked to Lavon at Firepunk and he said it sounds like it needs new transducer, governor solenoid, band adjustment and filter
