- Replies 15
- Views 2.9k
Mopar1973Man 4 posts
Hawkez 4 posts
dodgedieselnewbie 3 posts
Me78569 2 posts
Popular Days
Normal. I'm also running a ISSPro EV2 gauge and it will NOT drop to ZERO when the key is turned off. It will display the last reading. That is because the power is cut to the gauge and stepper
An electric gauge won't show pressure during starting. You'd need a mechanical gauge for that.
This is why posting video's can be more helpful..... Because that video shows a perfectly normal gauge operation. You're good.....
I posted my concern regarding my FP gauge on the CF a week or two ago... thinking maybe my lift pump was the issue. KATOOM indicated that gauge may not be working correctly and suggested I contact ISSPRO. I posted in their sponsor's forum but no response.
I just read another post regarding the FP gauge when the truck is turned off... whether it should or shouldn't drop to zero.. and the consensus is yes it should.
I just checked mine and it does not drop when I shut down.
Here's a video of a first start this morning. Shows the pressure at 16 from last night.. what happens when I turn the key (which was my intitial concern a couple weeks ago.. no build in pressure).. then I bump the starter to let the pump do its 25 second cycle.. then a turn on and start.
I initially thought it was my lift pump because I don't hear it when I turn the key (I thought I used to) but it always fires up instantly...
Do I need a new gauge? Sensor? How do i diagnose this?
Edited by dodgedieselnewbie
