OBDLink LX and OBDLink Android App
- Replies 26
- Views 7.7k
dodgedieselnewbie 8 posts
Mopar1973Man 7 posts
Me78569 4 posts
notlimah 4 posts
As for OBDLink. I found the Cummins ISB Volumetric number to be correct. Stock volumetric efficiency is 63% and you would "add" the percentage of offset to this number. Then
Well gang...
I'm back to playing around with OBDII Data again. I'm wanting to move the ScanGauge II to the 1996 Dodge Ram and use my OBDLink LX bluetooth dongle for the 2002 Cummins. The OBDLink LX is basically plug and plug. The Android Software you can get off Google Play. Now as for setup there is a bit configuring. Make sure to fill in the easy stuff like year, make, model. Now the important stuff is the volumetric efficiency, engine displacement (liters) and select intake manifold absolute pressure. You see the 77.5% that is figured from the base line for Cummins ISB is 63% then my old ScanGauge II had a offset of 14.5% so adding together you get 77.5%.
So I took off and did a quick test run.
So the numbers look like they are close to right. I'm going to need to do a nice long haul and get some test data to verify number. As for my display I use. You can configure anything you want. I added warning zones and normal zones making easy to glance at it and see the needle in a lime green zone or not.
