- Replies 10
- Views 6.3k
Mopar1973Man 3 posts
ebbtide357 3 posts
notlimah 2 posts
Cowboy 1 post
Popular Days
All good now one boot was loose tightened it up 30 lbs no problem now I can concentrate on other stuff ? thanks for all the input ?
If it's hard to make any kind of power under 2000 RPM, then I'd be looking at a boost leak straight off. You can also give the turbo a quick inspection. There is a how
spray bottle and water are not bad, but won't find the tiny leaks. But I think you are looking for a big one. (I use soap water first, then go to a leak detector. Good liquid leak detector stuff is
Seems my boost is low 10 maybe when I hit it I have edge comp set on 3x3 lot of smoke maybe leaking or glowshift hooked up wrong or plastic hose cracked hooked it up awhile ago but with my setup I should hit 30 lb quick I think or gauge is NG any ideas where to start
