What happens if you don't do an apps reset?
I know a couple of times I've had my batteries disconnected anywhere from 15-30+ minutes. I've never done an apps reset (didn't know about it). I'm asking because I'm still having issues with my truck (at times) dropping in and out of lock up.. like yesterday was horrible. Just releasing the slightest of tension on the accelerator would cause it at 55, 65 and higher.  Today.. no issue whatsoever tho.. Ran around 80 miles.. stop and go and highway.. never dropped out once. Not sure why it has good days and bad? I'm getting a TPS low voltage code every time I check and clear. I'm going to try the reset procedure tomorrow based on cumminsdog suggestion. And.. I still need to get a meter and check alternator voltage...
Edited by dodgedieselnewbie
  • Replies 49
  • Views 7.9k
  • dodgedieselnewbie
    dodgedieselnewbie
    Well... I ran around to 4 different auto parts stores. I asked if I could check for AC noise and a couple looked at me like I was nutzzz as I explained why. I put my meter on them at 2 stores but coul
    Think of all the times people have run there batteries dead and jump started the truck and drove on. Nothing happens just the range of throttle might be affected but most don't even notice.
  • I didn't see that in the image, but I wasn't looking either haha.   What decimal point does it read to in AC mode?
Well... this is what I get when I tried to measure in mV mode. Doesn't say what that means in manual.
Attached pic of specs.. Does this thing measure what I want?
Edit: Going to assume NO. Off to return and find another.
OL is overload.  The volts that you are measuring are too high for the range you have set.  You shouldn't have to measure in mV mode.  Set it to measure in 0.000 V.
That DVM will work just fine.
Edited by Hawkez
Okay.. received your message before I walked into Sears.. lol ran the test in the parking lot. Set to 0.000 .. I measured from each battery first.. drivers side fluctuates 0.044 - 0.050  passenger side 0.035 - 0.039
Positive lead touching metal connector around large black wire on alternator and neg lead to passenger neg battery terminal. . I get 0.108 - 0.110
Can someone tell me if these measurements are in range or out of range... or are so whacked that I'm still doing it wrong? I'm sooooo ignorant :-(
According to Mikes article on this...
"Normal output of the alternator is 13.5 to 14.5 volts DC but when flipped over to AC Volts it should never rise above 0.1 volts AC. If it does then you found your AC noise source."
So it looks like your literally on the cusp of being in and out of normal range, which would probably explain why this issue seems intermittent for you.
New development.. I was checking all my connections and tested some more with no change. I pulled the plug on the back of the alternator and see white residue in the plug..
How do I clean this connector.. can I spray anything in there? Compressed air only? I plugged it back in and the reading got worse... up to 0.2xx   :-(
Help!
Go by some contact cleaner.
I cant tell are the metal pins corroded or just dirty?
I can't really tell either.. but I don't think so.. too much white stuff in the way. I can't tell if it's corrosion or the white part of the plug is disintegrating.
Edit: I just got a got a paperclip and pulled out some of the white stuff.. it's a pasty cream texture. Some kind of grease? Should it be there?
sounds like someone used dielectric grease on it.  That is good.  As long as there is no corrosion
Okay.. I have some dielectric grease laying around somewhere.. I haven't used any in awhile but thought it was clear in color.
Not sure why it went from 0.1xx to 0.2xx from unplugging and plugging back in? I did do it while it was running.. was that okay?
FAIL... Anything over 0.1 AC volts is a fail...
0.010 to 0.030 Normal good alternator working normally.
0.050 Marginal. Some issue are reported typically and random in nature comes and goes...
0.100 FAILED. Diodes are shot and allowing too much AC voltage through.
Beyond the 0.1 and up you start to see electronics failures like ECM, PCM, or VP44 more commonly.
Okay.. looks like I'm heading to get a new one. :-(
I guess the voltage too high at batteries as well.. but why was there a discrepancy from one battery to the other? And why did it get worse when I unplugged and plugged back in the alternator?
I went to the Auto Zone first and they only had a Denso showing for my truck. Advanced Auto showed a Denso and a Bosch and said I need to see which one I have. My alternator does not have a label on it. How do I tell?
Not according to the dude working there. I questioned him... He said I had to know which one I had. I didn't drive the truck there so he couldn't look at it. I'm going to Napa tomorrow. They're more knowledgeable there.
The Denso was $135 while the Bosch was $240
Well... I ran around to 4 different auto parts stores. I asked if I could check for AC noise and a couple looked at me like I was nutzzz as I explained why. I put my meter on them at 2 stores but couldn't get an accurate reading. It bounced all over the place. Not sure why... but one guy was so argumentative with me.. I was getting ticked off. He said you can't believe everything you read on the internet and said it was probably my transmission. I said.. no.. I trust the info I was given and when I unplug the alternator I don't lose lock up.
Anyway.. I bought one at the parts store that the woman was most helpful and understanding. She said if the AC voltage   doesn't measure up (down) and I continue to have issues with lock up.. no problem bringing it back.
Found this break in the sheathing when I removed the alternator.. that I taped up until I can replace.
It's installed and all seems well. No lock up issue anymore and no TPS low voltage code. Yay! Thanks Mike!!!
I reset my Apps too.. I kind of liked it before I reset it. I actually need to step on the pedal now instead of just resting my foot on it.. lol
Checked codes today... TPS low voltage is back. Not causing any issues that I'm aware of. What exactly does "low voltage" mean?
Anyone?
The APPS is dropping out of normal operational range below its lower limit...
Accelerator Pedal Position Sensor (APPS) voltage is monitored when the engine is running. DTC may be stored if low voltage is detected on APPS signal circuit or low voltage is detected between Engine Control Module (ECM) and Powertrain Control Module (PCM).
