RV Battery Charging From Trucks Alternator
- Replies 34
- Views 6.9k
Mopar1973Man 12 posts
JAG1 10 posts
AH64ID 5 posts
IBMobile 3 posts
The 7 pin plug is setup to charge. My OEM fuse is 30A; however, due to the size of the wiring the most I have ever seen going into the camper batteries is about 15A. That's n
As Michael said it's the distance. Did you increase the size of the ground too? There is probably 30', if not more, of cable between the alternator and the camper batteries. At a 30A charg
wire size chart https://www.tessco.com/yts/industry/products/itm/automotive/get_wired.html
If camper batteries are way down is it hard on the Alternator?
