- Replies 29
- Views 10.9k
Mopar1973Man 9 posts
Chris O. 7 posts
GSP7 6 posts
dripley 2 posts
He need a ABS and SRS code reader. Not a OBDII reader. Like I've got one but it doesn't work on 1998 to 2002 Dodge Rams... http://pro.innova.com/Product/FullDetail/f968c286-07ab-46b7-bfd5-
As promised picture show time. Since my truck has no ABS issue i disconnected the right front wheel abs sensor. Now the ABS brake light is on. Pic. 3 Pic. 4 Pic. 5
Excellent scan tool for the money with OEM-specific coverage. AutoEnginuity also has live graphing and lots of other capabilities I never tried.
My ABS brake light is staying on, Need help figuring it out....1999 4x4 cummins, 160k miles. RWAL (rear wheel anti lock)
I read up in my Repair manual. CAB(controler antilock breakes),, RWAL,,, Reat axle speed sensor
Brakes work great, pretty fresh pads front and rear, fluid level good
I fiddled with the plugs on the rear axle speed sensor, CAB , etc. Everything looks good. Its a Clean truck, western desert area no rust
Is there any way to clear the memory in the RWAL C.A.B.
Any ideas what the problem is that keeps the ABS light on in the dash.
PS my '99 only has rear ABS , No front
Edited by GSP7
