HELP... rear brake issues
- Replies 47
- Views 8.9k
dodgedieselnewbie 22 posts
Haggar 8 posts
Buzzinhalfdozen 5 posts
CSM 4 posts
Hmm... just doesn't seem like a smart thing to do. Proportioning valves are in everything for a reason. I can see the larger cylinders, but at least put in an adjustable valve.
I'd put the valve back in also. you are getting full pressure to the rear brakes all the time now vs only when loaded heavy. I would guess your brake bias is all out of wack.
Why did you remove the proportioning valve??? It's in there to make the truck brake properly, especially when unloaded. I'd start with putting that back in.
I'm starting get really upset... my rear brakes are still giving me issues. History... Back in January I had the rear cylinders swapped out to the Chevy 1 ton and the rear proportioning valve bypass. Also had new shoes installed. All seemed well up until about a month ago. My work is seasonal so things picked up a month ago.. so more driving and braking began. It seems the warmer the brakes (fluid?) get.. the worse they get. Recently had the rear drums turned, new spring kit and adjusters installed. The shudder is back and progressively getting worse each day.. and again the more use they see throughout the day.. the worse the shudder. They also become extremely touchy (grabby) and the antilock is kicking in kind of easily.
I have not read any negative feedback on the larger cylinder upgrade or the proportioning valve bypass... So.. kind of stumped here.
I brought it to my mechanic and he test drove... when he came back he was shocked at how grabby, shuddery <--- for lack of a better word and how easily the antilock kicked in.
He suggested to go back to the stock sized cylinders to see if that helps.
Could the front proportioning valve be the problem? How do you tell.. or test?
What else can it be?
