Power Steering (hydroboost)
- Replies 18
- Views 14.6k
John, Yes, A high pressure hose goes from the ps pump to the hydroboost. A high pressure line goes from the hydroboost to the steering gear. Both the hydroboost and steering gear have s
1. The seal in the vacuum pump seals engine oil not the power steering pump. Look further for the P/S leak: at the pump itself, the steering box, the hydro boost, the pressure/return lines or fitting
I am equally as ignorant on this system and how they interact with each other.
So guys.
Have loss of power steering fluid (none left) . So Im guessing I need to pull the vaccuum pump/PSP assy out and reseal etc.
However when I was thinking about it - I realized I dont get how the whole system works ...... someone shed more light ?
Some questions.
1) Most people replace for the oil leak that occurs for the oil feed line to the vacuum pump. I'm sure I probably have this also ..... but I'm talking about loss of PS fluid in resevoir. So ? Do the seal replacements generally take care of PS side leaks ? Dont want to pull the assay only to find PS leak is something else.
2) How does this tie into larger system of steering gear and hydroboost. I have no PS fluid ...... so why do I not notice anything in terms of steering and braking. Im guessing the master cylinder is till producing enough power from brake fluid to stop truck with no funny pedal feeling. Just not getting the extra stopping power of hydro assist ?
3) Whats the flow of fluid. Is it from the hydroassist to the steering pump then to the PS pump or other way around ?
Things like that
