- Replies 60
- Views 30.6k
Mopar1973Man 23 posts
leathermaneod 11 posts
TFaoro 9 posts
CSM 3 posts
I got it all done and installed just before 4pm. Did my strap trick again. Worked good. So two ratchet straps to lift it off the floor. Then once I was able to roll the floor j
It'll buff out.
Weller Truck for $263 for a 5 gallon pail of Mobil Delvac 50 SAE transmission fluid. I figure since I was heading to the big city I could get it for a good price after finding out the loca
This topic is now closed to further replies.
http://www.quad4x4.com/syntorqlt.html
So since I know I got to put some sort of lubricant back into the transmission and NV4500 fluid by Castrol is no longer produced. So I called the shop that is rebuilding my transmission. He suggested 50 weight synthetic transmission fluid in a GL-4 rating. So I started digging around. I can buy a 5 gallon bucket locally for 50WT Synthetic GL-4 Transmission Fluid. Then did some digging on the Internet because I want to find out if any others where using the 50 WT transmission fluid.
Guess what... Another rebuilder suggesting the 50 WT transmission fluid.
http://nv4500transmission.com/nv4500-transmission-fluid
Now as for the 50 WT its used on most over the road truck transmissions as well.
http://pds.mobil.com/USA-English/Lubes/PDS/NAXXENCVLMOMobil_Delvac_Synthetic_Transmission_Fluid_50.aspx
So I think I'm going to give this a go and when the transmission get here. Unless there is any other comments or suggestion of fluids.
