Engine Stutter/cough on acceleration...is vp44 bad?
- Replies 72
- Views 31.3k
Zekeworst 18 posts
dripley 17 posts
Hawkez 6 posts
BrokeAssPainter 5 posts
double check codes with a good reader, how old injectors, 12psi is a bit low but don't think it would do that, noticed your oil pressure is low could be a bad oil sending unit that is cutting 5 volts
I am with you on checking a few more things. Having the injectors pop tested sounds like a good plan. I have an electronic fuel pressure gauge on the lift pump. I hooked up a mechanical gauge and d
Ok. Face in hands shaking head...embarrassment! haha *****Problem Solved***** Loose positive cable (can't believe I over looked that one) and Loose connector into vp44. Left my truck at Rincon
Hello all,
I have a 2001 24valve Dodge ram 2500 automatic. Wonder if my vp44 is bad. Today when driving, on acceleration I got a really bad stutter/cough in the engine. I double checked the voltage on the timbo apps and it is in spec and no dead spots. On the raptor pure flow the fuel pressure is 15psi at idle and around 12psi when accelerating. I have changed the alternator, it's in spec, I even disconnected fuse and harness to isolate if it could be that and it didn't go away. On low pressure side of vp44 primed to make sure no air on that side. No error codes and at my wits end what to do next. attaching a video if that helps.
any thoughts?
IMG_7611.m4v
