So i'm in the market for an exhaust brake. as i'm a total noob at these, can you explain what the good points and bad points are of the different types. or just recommend a good one that won't fail.
maybe some links to some good reading.  remember i have an auto, now built with billet parts.
  • Replies 11
  • Views 2.4k
  • AFIK the BD and PXRB are both air pressure actuated on the CR's. The Jacobs and Banks are the only ones I know of that are vacuum for the CR's.    I would get the PXRB. It will work well wit
Use a 6.7 manifold, bolt n a he351vgt and use an arduino to control it.
It should nearly bolt in place on your CR truck, just need the exhaust manifold.
interesting, do these turbos have an arm that move externally? one that a cable actuator might be able to manipulate? so no software and i could control it at will?
i'm still thinking more simpler. after watching a few videos i really don't think it's what i want. just an old school exhaust brake.
it's just an arm on the housing.  The actuator controls the arm using a motor.
Lots of guys use a mech setup on the vgt.  it is simpler but you loose a lot of really nice tuning ability.
If you want simple mech EB forget everything  I posted.  The VGT is a really nice turbo though, at least for me.  my thread in the 2nd gen section has some data logging with how it runs.
thanks for the info. but i'll only use this like 3-4 times a year towing my 5'er.
There are a lot of different choices between compressed air actuated, vacuum actuated, and even fully electric.  The two names you hear of the most are BD and Pac-brake.  The Pac-brake is compressed air actuated so that adds another level of complication.  The BD unit is vacuum actuated so that has it's perks.  Both those brands have a pressure regulator of sorts instead of your typical hole in the flapper, this give you better braking at low RPM's.
And of course there is the option of building your own.
Also, once you have one, you'll never go back.  I use mine all the time with normal driving unloaded.  It's also a good idea to use it frequently to prevent any components from becoming clogged with soot and such.
Edited by Cowboy
Exhaust brake... I use mine all the time I do 90% of all my stopping with it and the last 10% which is at speeds lower than 20 MPH. So my service brakes last will over 180-200k miles. Exhaust brakes are not just a trailer or towing thing...
This video is subtitled with the actions I'm performing. Take notice to the brake pedal point. This is also empty truck no trailer.
I would get the PXRB. It will work well with your pre-06 Auto and has good stopping power at lower rpms.
My Jacobs has been great but it's not an option for your year with the Auto.
