- Replies 14
- Views 336.5k
deehammer 5 posts
Me78569 3 posts
Mopar1973Man 2 posts
Hawkez 1 post
New to the site here so be patient with me. I have been wanting to join this site for awhile so this is as good an excuse as any.
The last two mornings I have seen what looks like vapor/smoke coming through my A/C or Heater vent. It is very light and almost unnoticeable but it drives me nuts. It only lasts about 15 seconds or so and is very light. It does not have a smoky smell it is more of a light musty smell but it is very faint you have to get your nose directly in it. Comes on when the truck is fully warmed up at 190 degrees. My blower motor is not on at all the heat dial is set to heat. When I drive throughout the day the problem never happens again. I think it is a small leak in my heater core that when my truck gets up to temp it vaporizes through the vent. I do not have a noticeable leak in the heater core (aka no antifreeze on the passenger floor) and my coolant level has not dropped noticeably. No overheating issues.
A little background...about a month ago I drained and flushed my Cooling system per Mikes directions on this site. Prior to the flush I was not getting my temp over 160 degrees which turned out to be a bad Thermostat. Now I am getting around 190 degrees constantly it has been nice to have real heat. My thoughts are my Heater Core may have been doing this for awhile which I never noticed or never vaporized due to not reaching temperature, or the flush jarred something loose (hadn't changed my fluid in 100k miles don't throw stones). Just wondering what you all think, I feel I am pointing in the right direction.
Don't know how to add my Vehicle info on here yet so here is a quick rundown of what I think is important:
1999 Ext Cab, 5 -Speed, 250 K Miles
