Steering upgrade
Hey guys looking to put new steering links on the truck. Ever since I put the DOR track bar on my stock steering linkage has really shown its wear. It'll pop while turning and you can easily turn them by hand. Looking to upgrade to the 09 kit, will this one work?
https://www.amazon.com/gp/product/B0046NUOLM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Also would it be worth upgrading the steering stabilizer? Or will that even work?
  • Replies 173
  • Views 36.1k
  • For those who see this thread and do some off-roading, I would definitely recommend having some sort of leveling kit or cutting the stud off of pitman arm joint. On a stock height truck, a couple inch
  • BIG-BLACK-DODGE
    BIG-BLACK-DODGE
    Ha yes we have good alcohol. Was a teenager playing Hockey in the States we would always find it funny how the U.S boys got drunk so fast... Lol our booze was definately more potent i think. The beer
  • notlimah
    notlimah
    Measuring now and then comparing that to what it is once the kits in would work. I eyeballed mine just to get it pretty straight and drivable but am getting it aligned by a shop this afternoon.
Well I'm joining the club with rockauto Mopar kit 52122362AL. Wanted to do this sooner but rockauto was out of stock. My y style is getting lose and clunky. Been waiting for this moment for a while now, getting excited :hyper: still under 300 to my door, here is a 5% off code. 8377585375304033
I'm not sure I'm too pleased with my kit.  It's been on two years and is starting to clunk.  My plan is to try greasing it but I'm worried it's too far along now and needs replaced.
Noooooo..... :cry:
Then maybe I'll drill and tap for grease zerks right a way
Might be wise.  I was gonna try going through the boot like @Mopar1973Man does, and it might take a few cycles to get the grease down in the cups but that's my hope anyways.
I'd rather force it through the joint if possible, not sure on clearance there. Can you cut yours open now that it's junk so we can see :hug:just kidding of course
6 minutes ago, trreed said:
Is not junk yet. :shifty:
Is it just easier to rotate by hand but still tight when looking for slack
No idea.  Have had the pickup back for just under a week and been too busy to crawl under and look.  Just know it's a loud annoying pop when I turn in either direction when moving at low speeds or no speed.
Granted, I have done my fair share of driving on U.S. Forest Service roads, so I'm guess that had something to do with it.
Edited by trreed
That looks like where the adjusting sleeve is but it came installed on mine.
Yes, I'm guessing it's to keep everything in line so it's straight and not twisting. And maybe to get full range of motion out of the joints. Idk.
  • 2 months later...
Hi Guys!
Sorry to be the gravedigger on this thread but it is very helpful to me here. I found it an hour ago and red through all pages.
Maybe someone can answer me a left over question:
I wanna do the upgrade on my '01 1500. Im gonna install some 2500 Springs soon which will level the front. Also im running 16" procomp wheels with a -12 offset.
As i understand with the offset there should ne no clearance problems on the studs or the tierod-ends themselfes (am i correct?) will there be a problem with the draglink to the? My problem is: im from germany. the technical inspection here will not allow any modifications to these parts i think so a direct bolt on with no issues is needed. It looks like "it could work - but it also could go wrong" on me.
maybe someone can tell me the "truth" :D
any help is appreciated!
thanks
