Front Axle U-Joint Replacement
- Replies 18
- Views 5.8k
dripley 4 posts
CTcummins24V 3 posts
CUMMINSDIESELPWR 2 posts
Cowboy 2 posts
Popular Days
If you are replacing the unit bearings/hubs, you can use a hub puller and a hammer. The puller may actually break the unit bearing in half. The best way, back the 4 bearing bolts out about
keep beating on it like it owes you money. and dont be gentle.
I'm currently in the project of replacing u-joints and bearings on the front axles. How do I get the bearing housing off? (Of course I have already taken the four bolts out.. And the axle nut.) I have taken a solid hammer to it, including a chisel and 5 pound hammer. Any tips or tricks that you guys would recommend?
Thanks in advance!
