Travel trailer newbie!
Hey guys. My wife and I have found a great local company that rents 2015 travel trailers so instead of buying we will most likely rent for our travel/camping adventures.
Although I've towed plenty before, I've never towed a travel trailer and with that, not entirely sure of neccesary things I should bring.
For you more salty travel trailer guys, what are things you can't leave without when towing? Any sort of check list or things you've found helpful in the beginning of your towing days to stay organized and bring what was needed?
I try to be as prepared as possible, especially with the family involved, so I look forward to all of your insight!
  • Replies 126
  • Views 28.4k
  • Well had a good trip this last week. Went to to Lynden, WA for the Puget Sound Antique Tractor Show.    Mitch was the first real test in towing I've put the truck through and she did great.
  • Thats them. I know when I hook up and load with the 5th wheel mine sits level and I was surprised that the travel trailer you hauled made you look a little squatted. The leveling spacers upfront expla
  • I also have the camper package like @dripley without a leveling kit and it sits level when loaded.
9 minutes ago, Mopar1973Man said:
I said the same thing to as a possible cause of the tail squatting. Now you have to remember he's got that heavy flat bed on the bad it much heavier than the stock bed too. I had him scale the truck last spring and it was like 8,9xx or 9,0xx pound truck roughly empty.
Heavy but nothing crazy. I come into the scales at 8400ish most of the time, so he doesn't have enough to make his RAW that heavy.
3 minutes ago, TFaoro said:
Different spring rates on the 2nd gens making them stiffer no matter what?
Possible, but the angle of the control arm should still make a difference.
Edited by AH64ID
42 minutes ago, TFaoro said:
I did the 1" spacer to begin with. Ride didn't changes. I then changed to the 2" spacer and ride didn't change again. Maybe it helps on the 3rd gens to be lower??
I'm going to keep my 2" and put bags on the rear to stay level. I usually don't have enough in the rear to squat the truck too much.
Only reason I'm looking to go with the 1in is to be as close to stock as possible and avoid needing bags. I don't mind either look (stock rake vs level) but I'd prefer more rake then level especially when towing.
Do you have to remove the shock to put new coil spacers on? Or just jack up the body and get a spring compressor and swap the spacers and call it a day?
Edited by notlimah
Unmodified suspension, but perfect level for towing. This is why I typically will not suggest any leveling kits because a heavy trailer will automatically pull the nose up even on a stock suspension. So if you using a leveling kit then it always going to be possible to have a squatting truck.
Like comparing to @Taz truck to mine I'm 3/4 ton towing 1,000 pounds more without any leveling kit. He's a 1 ton truck and 2" leveling kit and it squatting with light load little utility trailer.
Unhook both sides of the sway bar, unhook the track bar, remove the shocks and shock towers, then lift the frame far enough you can get the springs out. The spacer should fall out with it. Then do the reverse. Much easier if you remove the tires to  drop the axle too.
Do you have a weight distribution hitch for your camper? Most of campers I see have them.
Ok... Same trailer then... Either way stock rake with no leveling always turns near level towing.
Here is a reference. Low miles on the truck and 0 psi in the airbags. 2" level up front and approx 2,750 lb pallet putting the RAW around 5,500lbs and I wasn't quite on the overload perches.
I will say that I have noticed that my airbags are keeping my springs much more springy vs my brothers lighter, but same spring pack, 2500 Hemi. He sags much easier and rides lower when empty. So I would say that use of airbags extends the life of springs.
Edited by AH64ID
