- Replies 9
- Views 2.5k
I think the iron is pretty low. Iron is the main component in this engine so it stands to reason it's in the sample. It's not even to a severity 1, and quite a ways from it IIRC. Wear metals are just
Here we are again another year down the road... Notice that the TBN after 11.5 months and 6400 miles is as high as many CJ oils start out at.
Looks good John! I'm afraid of what they'd say if I sent a sample in
This is a good reason why I run Amsoil AME in my truck.
As you can see the oil had over 10K miles on it. I ended up running it a little longer than I have been the last few years because I did a trip in May/June to Arizona and didn't figure the additional highway miles would hurt, and they didn't.
10,583 miles, 308 hours, 733.8 gallons, and just under 13 months.
Of those miles 2679 were towing which is a decent percentage when you take out the 3544 miles I did in 6 weeks to/from Arizona, which is just under 40% towing.
The oil looks like it had quite a bit of life left in it but I'm good changing it.
Not to bad for making 410/850 to the ground and using the truck pretty hard.
*Don't mind the two cautions on last years change as they were a carryover from the Delo 400 LE on the change before.
