- Replies 19
- Views 6.6k
98whitelightnin 10 posts
Mopar1973Man 5 posts
dripley 3 posts
angus 1 post
Check fuse 9 in the cab. It might be cracked and opening and closing the circuit as it heats and cools. As you'll see it covers the PCM, A/C and OD circuits.
Might want to do the AC noise test.
Now being its electronic device failure did you do a AC noise test? I do see any results of a AC noise test done. Don't risk your new PCM to the damaging AC noise problems. Funny so many p
Having an intermittent problem with my 1995 12v lately. It's loosing overdrive while driving down the road and also the ac stopps cooling at the same time. The overdrive on/off button does not light and has no function when this occurs. I can manually lock the converter in 3 when this occurs. This happened first Tuesday night leaving dinner and by the time I got home, 5 miles, and turned it off in the driveway, they do switch light was working fine. Tonight we went to dinner and everything worked as normal but when we left dinner, it never would shift to 4. I pulled over and unplugged the factory temp sensor with no change. Drove to Cheesecake Factory and when we came out the od switch was functioning normally again along with the ac blowing cold but the trams temp light was flickering so I pulled over and plugged the temp sensor back in. Trans shifted normal for about 2 miles and then started dropping from 4 to 3. I locked the converter and it kept dropping from 4 lock to 3 lock and then back up and down for a few more miles until it lost 4 completely and no ac. Every time this happens, I loose control of the od on/off switch and ac cooling.
