Brake lites stay on when hot.
- Replies 11
- Views 3.1k
Wild and Free 4 posts
dripley 3 posts
AH64ID 2 posts
Haggar 1 post
AH and Drip, I agree I don't think I would have made the connection. Great job Wild! AH, I guess it didn't really "keep the brake light on." That was a symptom of the pedal n
How I wound up with the idea of it being the power steering pump breather cap was last weekend I had gotten home and noticed the brake lites were still on so I popped the hood and popped the cap off t
Brake Lights did not stay on once today, looks like my little tweaking on the cap did the trick. Went out and popped the cap just a few minutes ago and there was a very slight positive pressure wh
Have had the issue of my brake lites staying on when the engine was hot in warm weather. Has been going on for about 3 years or more and I always thought it was due to a misadjusted or sticky switch. I even had intermittent cruise control kicking out on its own so I thought this was the problem. Tried to adjust switch @ brake pedal but there is really no adjustment on a 3rd gen other than maybe bend the bracket which is really thick.
Long story short I always had to pull upon the brake pedal when I shut the pickup off to get the lites to go out just became a habit but when my wife and I go to the water she does the trailering and I am on the boat and have to holler at her to make sure brake lites are off.
Got tired of that so decided to look into it. I had noticed from my steering gear swap and just normal checks that the power steering pump always had an abnormal amount of pressure when cracking open the lid even when cold so I am thinking this had something to do with it. There is a breather built into the cap and the dipstick is integral to it as the breather passages go through it.
Popped the dipstick out of the cap and found there is a rubber check valve in between the cap and dipstick which looked good. cleaned everything up and nothing was dirty or plugged so figured the rubber must have swelled and was putting too much pressure on the breather hole.
The cap itself has a couple of tabs that act as spacers molded into it that the rubber check sits against they were maybe 1/16" high so I ground them off flush and put it all back together and so far it has taken care of my issue the last couple time I have driven it. today will be the bigger test going to be hot and pulling the pontoon to the water so if it works today I know I found the fix.
