- Replies 17
- Views 3.4k
thedsmguy 3 posts
jlwelding 2 posts
Wild and Free 2 posts
JOHNFAK 2 posts
Ok, So its dead from all I can tell. I want to buy a different one, should I buy a rebuilt bosch unit from my local supplier for $1150 or should I go with Jkidds are they the same pump? Should I go with the Blue Chip type X pump they suggest that it gets better gas mileage ( I tow a 3-4 car trailer and will be going a TON of miles ). I'm assuming that my truck will run better even better then it did prior to the pump dyeing due to wear etc. Is there any other options out there I'm not thinking of? I would also like to do a upgraded lift pump, maybe the fass system. I feel I'm on the right path, I'm just wondering if I should pay a little more to buy my pump from a local company that was rebuilt by bosh (unknown if its a new computer etc) or should I go with the fancy dancy one from Blue chip (known new components) or spend some time and save a buck by going with Jkidds? Thank you. Paul
