1689 and 1690 error codes (ECU)
- Replies 8
- Views 5.5k
MadProf 3 posts
dripley 1 post
klcammie 1 post
01cummins4ever 1 post
Aloha - I am back from Hawaii! And apologies if this was answered already somewhere else. Here is what happened:
It's a gen II 2002 24 valve diesel 3500
Changed VP44 and ECU in Jan 16 - truck ran fine other than issue with TPS - which we changed as well (sometime spring 16).
Had "no-start" issue with error 1689 a couple of weeks ago and swapped out the fuel relay for a new one - truck ran fine but pretty rough - felt like missing cylinder.
Today truck started, drove around for a bit (but ran rough); we shut it down, tried to restart a while later and now, no start again.
Pulled codes and it is now reading 1689 and 1690 - swapped relay out for another one - but truck is dead - (well, semi-dead) - starter works, lift pump works (has pressure), but no fire.
We had a ton of rain and moisture (live in hurricane country) - could it be wiring, i.e. between ECU and VP44?
Any help/ideas are greatly appreciated!
