Transmission Relay Question... (torque converter lockup related)
- Replies 13
- Views 3.6k
Popular Days
The 100 hz signal is not an AC signal. It is a pulse width modulated DC signal running at 100 hz. A PWM signal allows them to vary the field current to the alternator, controlling its output.
@Mopar1973Man, @Me78569 I helped all I could
Kind of an obscure question, as I was looking at the wiring diagram for my truck. (see link) @Dynamic If you have any input here... I would appreciate it. I am trying to figure out why the trans relay is in line with the alternator field.
If you look at the PCM on the left side, about mid way down you will see a GEN FIELD DRV, in dark green. This field runs 100hz AC to the alternator from the PCM causing it to charge. Lower you will see a GEN FIELD OUT, returning from the alternator to the transmission relay.
Why would they do this? Why not run the signal for the trans relay directly to the relay? Why allow the non steady state voltage regulator to control the relay? This seems like it should be simple and I am missing something.
Edited by CSM
