Looking for Staff Members
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 289.5k
  • Quadzilla Power
    Quadzilla Power
well I know that's not true because I wrote a lot of them.
Like my economy tune could be adapted to fit 100 HP
I'm not into building performance tunes. Being I drive close to 1,000 miles a week but I do have an awesome economy tune. Matter of fact even with my current setup and 245's tires running 82 MPH at 2,500 RPM I still netted 19.58 MPG for the nearly 100-mile trip. So, there is a lot more to it than just fuel stretch.
I just bought a iquad, a new turbo (smeding 362/65/14) with 4in downpipe to 5in exhaust ,and 125hp sac injectors.I was told this was a decent set up from where I got it (Rather not say where incase some one disagrees and wants to bash) but would have a little bit of turbo lag Can any one point me in the right direction for some base tunes? I have tried Mopar mans tunes for towing and DD but they are both lacking in the bottom, once the turbo spools its gets up and boogies in a hurry, maybe the turbo is to big or just needs to be tuned out better for my set up? im not overly concerned with smoke living in rural Minnesota no one really cares as long as I don't leave a cloud a mile long. would like a good tow tune and a good DD tune and a get up and go tune if I go into more populated areas and need that low end/get out of the way power. all the information on here is really overwhelming and partially confusing because a lot of people don't have their set up and total mods posted.... maybe for good reason :evilgrin:
Have you worked through the tuning article?
The lower section has a how to.
Mainly if you want more bottom end add more fuel.
I did read through that and it was pretty confusing, im not so much in the technically advanced area. ill try adding some more fuel to the lower boost areas
Quote
Section 2: Getting Started with Quadzilla Adrenaline V2 Custom Tuning
When you are starting to use V2 Tune on your truck you should follow these steps.
1. Find your starting %
2. Set your base map
3. Fine tune your base map
4. Set your Wiretap start point
5. Set your Wiretap Fueling %
This tuning should not be done on busy roads or in any place that risk of crashing or hurting others. A back country road is recommended.
Save your tune after EVERY change.
Don't forget you are able to create more than one custom tune so you can setup a race tune or tow tune or DD tune.  Tune your custom tunes with something in mind. Don't try to make the truck do everything on one tune.
Step 1.
If you have stock injectors you can set this to 100% or above so you can skip this step and move to Step 2.
Use LVL1 and the Power reduction % to find a good point for the CANbus fueling %.  For 50 hp injectors start at %95 and move up or down by %1 depending on if you get smoke when you snap throttle from 0-%50  while in gear.  Find a reasonable % for smoke output vs low-end power.  Remember this is to handle off idle power.   ENSURE WHEN YOU ARE TESTING YOUR STARTING POINT YOU GO %100 THROTTLE INPut.  You want to set your smoke level as WOT.  This will give you the most resolution in your throttle movement.  IE: if you truck maxes out fueling at %30 throttle, what's the point of the other %70 of throttle movement.  Make %100 fuel %100 throttle.
Good starting points per injector size ***use only as a guide you will need to go through some trial and error.
50 hp injectors %95
100 hp injectors %90
150 hp injectors %85
200 hp injectors %80
250 hp injectors %75
300 hp injectors %70
Once you have found a good starting point Set your 0 PSI % to this power reduction % and set your Power Reduction scale to a % that you want to allow for a valet mode or antitheft or emissions or whatever for reduced power.
Step 2.
Set Quad to Power LVL3
Once you have a good starting point defined for 0 psi scaling increase every % by 1 as you move up in psi.  As you hit 10-15 psi you can move up by 2 or 3 % per psi until you max out at ~%130.  You will notice that the Canbus HP limit is somewhere around %130 depending on the truck and the mods.
This should give you a good base fueling map to fine tune your truck by.
Step 3.
Once you have your base map do some 0-%50 APPS take off's on LVL3 only.  Pay attention to Boost numbers and smoke output.   a video camera is very helpful.  ENSURE YOU ARE NOT AROUND OTHER DRIVERS OR PEOPLE WHEN DOING THIS!!!!!!
You may notice puffs of smoke as PSI climbs, reduce the % at that psi point by 1 if smoke is too much.  If the truck feels laggy at a given PSIincrease by %1 until your truck feels good.  Keep in mind that smoke from the tailpipe may cause flooding of the turbo.  A truck will respond best when there is a slight haze under high throttle input.    Don't be afraid to use high TPS input to get the truck moving.  That is what the throttle pedal is for!
Tweak your 0-30 settings until you are happy with how the truck drives on LVL3
Step 4.
Once you have your CANbus tuning done move to wiretap tuning.  Wiretap fueling will increase power significantly when it is used.  Depending on your wants you can set low limit fueling for wiretap.  This will allow for smoke reduction when wiretap comes on.
Set your low limit for a PSI that is above your normal DD / cruising PSI.  IE if you drive to work every day and don't normally hit 10 psi  set your low limit above 10 psi.     If you want wiretap fueling when you typically drive set the low limit below that.  I would not recommend setting this below 5psi as smoke control is much harder.  Remember low limit allows for wiretap scaling below that point.  TPS min also comes into play so set your pump TPS min at a point that makes sense for your driving style / needs
Step 5.
Timing tuning is a little tricky and should not be taken lightly.  I suggest that you keep your timing tuning configured as
1500 max: 14*
2000 max: 18*
2500 max: 22*
3000 max: 25*
max: 26*
UNLESS you have time to do a good amount of data logging and figure out what is best for your truck.  Keep in mind that aggressive timing can cause issues. The above should be considered very safe on pretty much any truck.  OEM timing will hit 26* in stock form.  What you will find however is under the curve power will be improved by adjusting these settings.
Step 6.
Once you have set your low limit for Wiretap fueling set your scaling.  This scaling will set how much wiretap fueling is added before the low limit is reached.  If you want no wiretap before the low limit set this to %0, if you want half set this to %50 and so forth.
Typically I leave this between %15 and %25 depending on how aggressive you want the truck to feel when DD'ing the truck.    Setting this % higher will increase smoke output off idle.
Did you work through these 5 steps in that article?
ok so if I go through these steps and want to make a tow tune, do I repeat with a trailer on loaded or do I just tweak it a bit to make it more aggressive? im not sure what canbus is or when to use some of the settings like pretty much anything in the timing and how do I know how long to set the PS
Edited by zxzredneckzxz
if you just want more meat down low then you only need to work through steps 1 and 2.
Can bus fueling is your sliders for fuel for 0-30 psi
I am guessing you will be happy if you add 5 or 10 % from 0 psi to 10 psi.
I've got a smaller turbo. (60/60/12) plus my injectors are 150 HP (7 x 0.010 @ 320 bar) so I require less fuel to spool up. Bottom end for mine is just slightly smoky but clean enough to keep big city cops off of me. Beyond that I built the tune to keep the wiretap high in the boost realm so you run mostly on the CANBus till you stand on it. Designed most for MPG numbers.
You can bring the wiretap down in boost pressure and it would kick in quicker.
That the beauty of Quadzilla you can have as many tunes as you want.
  • 2 months later...
Got a question, so Is brokepainters stock dd tune look like a very good tune for a mainly stock truck? I would like to know because I've read alot of how I should tune towards my stock truck and his tune is quite different than what I hypothetically came up with. Would his tune be a good base for me to try and maybe adjust if and where needed for a stock daily driver/fun ride ?
Thanks
Edited by RdieselZ
On 4/13/2019 at 6:16 PM, BrokeAssPainter said:
^ this tune Me.
looks like a typical stock truck tune,  timing is a little "safe"  in the 2500+ area.  I would not have any issues adding 2* of timing from 2500 and above
^ this tune Me.
Would it be safe to change timing to 17,20,23,28,30?
  • 1 year later...
i have 02 dodge 2500 24 valve cumins 6 speed
125hp injectors
afe intercooler and hose
afe intake elbow
air dog 100
BIG LINE KIT
s464 borg warner turbo non wastegate
dual disc race southbend clutch
i need a good tune for street  and a hot tune aka "hold on tight"
Edited by 24valve gear jammer
Look in the starter tune download section.
