Vehicle/ Truck Communication and CB Radios
- Replies 13
- Views 2.9k
JAG1 6 posts
sooxies 3 posts
Mopar1973Man 1 post
IBMobile 1 post
Popular Days
If it is a steel whip antenna you can shorten or lengthen the antenna by moving the whip part up and down. It is usually held in place with a set screw. Some fiberglass antennas have a metal or wire t
I had 3 or 4 CB's, some were the old 23 channel, along with 3 antennas. I couldn't get any to work until I found out that the antenna mast has to be tuned or matched to the CB with an SWR meter.
I bought this hand held (Midland $ 90 bucks) with an antenna hook up at the end of the 12 volt power cord so you only contend with one wire like you would a microphone. The longer battery case IS rem
Whats best? Hand held units OK for close range? I know antennas are very short lower than my rv roof but will it affect close range with other RVrs?
Side Note: Talked with a guy today involved with emergency response, says we all should have CBs because the possibility exists that common communications could be compromised some day with power grids taken out. Sounds good anyhow.
