Looking for Staff Members
How do I manually install The Quadzilla Driver / Load the Quadzilla V2 tune on Windows 10 / 8 / 7
  • Replies 85
  • Views 54.5k
  • I just want to say thank you. This was a long process for me to get this updated as I’m totally lost when it comes to using a computer but there has been a lot of time and effort into setting this up
  • What you do????     Also at this point I am fairly confiedent that you won't need to flash another tune in the near future, unless someone finds something big.  I have been driving on this f
  • I pinned this as I feel like it will help a lot of people see it.  As I said above Please print out the PDF or use another computer so you can follow the steps.     The process does work if
I think it's working, at least it's thinking and I did have to push run anyway, will let you know  in a few . Thanks man.
5980e929c7c69_2017-08-0115_44_44.jpg.047f30f72d8e451746d1cab7bffb78bf.jpg5980e90c8bf5e_2017-08-0115_44_31.jpg.71f4dc7e1e1625c68f8ef72621edc36f.jpgIt worked this time, thanks Nick.
hello, i am new to the Cummis world. I'm putting a 02 cummins in a f250, and i purchased the IQuadbt. i have been trying to install the flash program on my compter and  get the following message when i do it-
Copyng driver
File not found- QZ.Inf
sys cannot find the path specirfied
Devcon failed
 now I'm running windows 7, 64 bit. i have tried all that i know. My Adrenaline is  ADR1002. i have yet to plug it up to the truck.
i will also put a thread of my build up in the conversion section. Thanks for any help.
  • 2 months later...
So I’m trying to get the new flash on my quad. When I push the “run admin” button on step 2 it pulls up the black box and starts the count down. When its finished it shows this screen saying the driver failed
Also it shows this screen when I first try to run the program. Don’t know if it means anything but..
Is the box plugged in when you run step2?
Hello, I am having issues with step one and two. (similar to the issue above however I'm getting less results than he is)
I have windows ten and step one would not bring up a box so i did the settings manually as if a 8.1 so i would assume and hope that is all good.
When i got to step two I had the same issue, the box comes up briefly, not even long enough to see the box load, and then it shuts down, i can not use my quad (v2 custom tuning for VP44) until I flash it as the app crashes for one and when on any power level above 0 it has the rough high idle symptoms which it sounds like two flashes will cure this, thankfully. I just need to get past the PC issue.
Please help me out when convenient  the truck is not a daily or anything of necessity so it can sit until this is resolved.
I have insured the cable is a data transfer cable, the box makes a chime on the PC, I am considering starting over on an older lap top with windows 7. Think I will try it real quick and post results, it probably will be an issue with my PC alone.
I have friends with Cummins who would like to use Quadzilla due to the infamous reputation they had in the past and i would really like to be able to keep them swayed away from edge products like the one i just took out.
Lastly I would like to thank Quadzilla for delivering the diesel community with this amazing tuning technology, I am excited to see what it can do to benefit having DAP 100HP injectors and a super B!
Edited by BobTheRepairMan
More usefull info and spellchecking is always good
did the computer restart allowing you to choose "disable unsigned driver enforcement"?   windows 7 is easier to get going because you only need step 2.
  • 3 months later...
trying to reflash my 4k box so it will work right since cel doesnt come on. it wont read the module as i followed all steps for windows 10.
@Me78569 Is it normal for it to be a pain to reflash the box? I’ve only been able to do it once with out a problem. Every other time ive had to fiddle with it and take a lot of time to get it to connect.
timing is key.
If I remember right, I clicked the flash program to open, then plugged in so that i could click the find module button before the 2nd beep.
Really depends on the computer though, some are easier than others.
33 minutes ago, Me78569 said:
timing is key.
I’ve been trying to flash your long idle version for a good 1.5hrs. Done a whole bunch of different combinations. Even deleted my quad driver and installed it over again. Still nothing. Guess I’ll give it a shot tomorrow
Yes, but you need the 4k reflash files. If you are running standard tunes it will probably not set the CEL
http://quadzillatech.com/TunesDownloads/V2Tunes/ADR98024kV2.6.1.exe
Pretty sure that is the latest 4k V2.
It is normal to have to cancel and try again one or more times. Also, make sure that you have a data version of the USB mini cable, not just the charging version.
If it still isn't connecting, make sure that the driver manufacturer is Quadzilla, it will be found under the COM/LPT ports and should be called usb to serial converter. If this is a foreign language, you may just need to send it in for us to do it for you.
I got it to finally connect and it said it had the 4k beta on it. Before it would always turn cel on with the basic 4k tunes. But now it doesn't seem to fuel as hard. You could hear motor change sounds when it would really hit but not it doesn't.
Does the computer beep when you plug in the box?  sounds like either you have a charge only usb or the driver isnt installed.
21 minutes ago, Quadzilla Power said:
I'm honestly not sure about the beta one. I would put the 4k std tune on it if you are doing some legacy tuning. The 4k hard-fuel is good too, but I think you would like the standard better.
After you put the older one back on, if it still doesn't work well for you, send us a note here:
http://quadzillapower.com/contact-support/
or PM us.
ADR9802V2 - StandardFuel.exe/ is this the file your talking about loading onto the 4k box? I'm emailing as well. Just trying to get my power back.
