Mike, what's that stuff again
What'd you use to clean your engine bay again?
What about the underside?
  • Replies 15
  • Views 2.2k
  • The Clintons already have some strange mysterious non-stick goo which somehow not only prevents them from being held accountable for anything.....but also clouds the mental capacity and memory of thos
    Here you go... http://www.homedepot.com/p/ZEP-128-oz-Industrial-Purple-Degreaser-ZU0856128/100047759
What did you use for coating the underside?
Maybe i have you confused with someone else, lol.
I thought i remember someone saying to spray with an oil to keep dirt off etc...
Thats just normal oil leakage.  People call it Cummins corrosion control. :whistle2:
Complete opposite. The oil is for rust/corrosion, and it attracts dirt/dust. And from my front crank leak and oil pan leaks, my front end has no rust. I'd rather have oil that you can wipe off, versus rust. I coat the frame, underside, in the doors/wheel wells/rockers. I live in the northeast and lived in the midwest where salt and pretreaters run rampid and eat away trucks before they fully live their life.
I think i remember now...
Back when i did some concrete pumping work we sprayed hydraulic oil on the parts that could get cement on them. washed off real easy and nothing ever stuck!
52 minutes ago, JAG1 said:
Need to spray the entire Hillary gang with that stuff.
The Clintons already have some strange mysterious non-stick goo which somehow not only prevents them from being held accountable for anything.....but also clouds the mental capacity and memory of those who support them.
Maybe we need to find out what that stuff is and use it on our vehicles. :think: We could call it something catchy like "Eludes ALL".....
:lmao:
How does everything seem to get politicized....
I guess it's just a sign of the times.....
