- Replies 39
- Views 13.9k
Mopar1973Man 16 posts
LorenS 11 posts
NIsaacs 7 posts
Me78569 2 posts
Just unplug the fuel heater. Best setup yet with 30.5 Inch tires. These get the final ratio down to 3.69:1 to the road and awesome for towing. Never once did I have a EGT issue all the w
drag up from the bottom and click and drag the sensor data you want to move in place. Here is the Iquad App user manual. http://quadzillapower.com/content/Forms/Instructions/i
1998.5 to 2002 Dodge 2.7 is the right one...
Where does the EJWA pick up the fuel temperature? I hadn't driven my truck for 2 days and went to start it up this morning. It was 32 degrees outside and the fuel temp was showing 41 degrees. After a few mins of idle and scraping the windows I started driving and the temp was showing 64 degrees. Is this read from the fuel in the VP44?
