No WTS light, Unable to start in 2nd.
- Replies 29
- Views 7.8k
dripley 9 posts
Cronus577 8 posts
Mopar1973Man 5 posts
Me78569 5 posts
#1 All these are pretty good signs of ECM problems. Parts of it are failing. #2 Could be your VP is failing also. Not sure on that. Do you have a fuel pressure gauge to monitor the lift pump pres
No WTS light is the dead sign for the ecm, but we have to remember that the Juice recieves info from the ecm directly. So the ECM can't be %100 dead. No lift pump blip is another sign of
Not to mention if you start cutting up the wiring harness and are electronically challenged as I am, you pen yourself up for different problems down the road. My ECM failed many years ago and th
I have a couple of issues with my 1999 24v that's been bugging me.
1. Lately it's been getting cold here in New Mexico and I noticed that my grid heater doesn't cycle until the engine has been started. The wait to start light never comes on anymore, not even for a split second, and my lift pump no longer does the 1-2 second prime before engine start. Is it a bad ECM?
2. My truck is a 5 speed nv4500, when I first picked it up I used to be able to take off from a dead stop in second gear just fine, plenty of torque to get it to move even starting on an incline. Now I have to start off in first gear slowly, it feels like it's hesitating/bogging down. I can't even think about second gear starts anymore. I'm not sure what it could be.
3. I just replaced my APPS sensor thinking the old one was the problem but I guess not, followed all directions as stated on the piece of paper I got from DAP. When I monitor the throttle % on my Edge monitor it'll only go up to 89% at WOT, I'm stumped on what it could be. I've cleaned all the contacts in the engine bay, replaced the alternator trying to make sure it's not any noise causing it to read but it's still only goes up to 89%.
My mods are: 1999 ram 2500 24v 5 speed w/351k miles, Edge Juice with Attitude, DAP 7x.009 SAC injectors, AFE Intake manifold, BD pulse manifold, Head studs, FASS 150, BHAF.
The truck doesn't throw any CEL's or codes scanning with the Edge. Any advice is appreciated
Edited by Cronus577
