shake between 25 and 35 mph
- Replies 48
- Views 10.3k
Drive shaft maybe. Had an old 68 Falcon that did that and nobody could figure it out until the drive shaft fell out. Lost the front yoke or u joint not sure which now. That was back in 1969, my first
Your truck driving around =
Well it's not the front drive shaft. Pretty sure it is the carrier bearing....Mike was right I guess, the wrong way to install a carrier bearing is with a hammer hahah
A new issue has come up.
I have a very noticeable shake between 25 and 35 mph. it is VERY similar to a tire being out of balance, but I have never had a tire do that at such low speeds.
Doesn't matter if you are increasing or decreasing speed, doesn't matter if you are on the brakes or on the throttle moderately. WOT you don't feel it but that might be because the truck is rough anyways.
Does matter what gear or rev, just that mph is between 25 and 35 mph, it clears up pretty much as soon as you hit 36 mph.
Tires?
