$7.50 for a quart of ATF+4 ! ! !
$7.50 for a quart of Valvoline  ATF+4 ! ! !  That's crazy !
I replaced the rear drive shaft seal on my 241 transfer case, Figured Id change the oil too. Cheapest I found is $7.50 per quart for valvoline atf + 4.
Local crappy Walmart didnt even have any. They redid/ rearranged everything in that store and they dont stock alot of stuff they used too
Looked at my old receipts and I payed $2.50 a qt for the ATF + 3 before the +4 came out when I did my Transmission
Im going to try another walmart in another town  UGH !
Edited by GSP7
  • Replies 7
  • Views 2.7k
For a brand name $7.50/qt. is the going rate.  You can try Amazon or E-Bay but with out free shipping for get about it.
O'Rielly has their store brand for $6.39/qt.    atf+4.jpg
That's why I put amsoil in pretty much everything that I don't have to change too often, figured it's cheaper then oem stuff and better then  most brands. used to run their motor oil too but decided to switch to more common stuff. been running cen-pe-Co for a while now, seems to be good stuff.
Well' I got some Napa ATF + 4. It's Valvoline, says right on the label, and says synthetic too, $5.00 a qt
:thumb1:
If it has ATF+4 o nthe label it is synthetic, it must meet standards to have the name on the label.
Yes, I found the list of Chrysler licensed service pack ATF+4 brands. There are quit a few.
Wallymart SuperTech atf+4 is also, but I dont think the base oil is synthetic, least it doesnt say on the label
Edited by GSP7
Anything marked ATF +4 is Synthetic, The spec for ATF +4 is VERY specific about the fluid.  One thing is that all oil must be made of Group III oil which is a "synthetic".
Edited by Me78569
FWIW i have been using the Wally world ATF4 for the past few years. The price is good and it it should meet the specs for ATF4. So far so good. I have met 2 dirt men working for me who use Super tech 15 40 for all their equipment in the past couple years. It does meet the same specs as other oils. But I have no idea of what the additive package is for the oil. So there is most likely some differences I do not know about.
