- Replies 9
- Views 5.9k
Hawkez 2 posts
IBMobile 1 post
CTcummins24V 1 post
Royal Squire 1 post
After installing a new radio/receiver I discovered that I had two speakers that did not work: the speaker in the driver's door and the right-aft speaker. I bought new speakers from Amazon: 2 6"X9" fo
Walmart has Pioneer 6x9 speakers for pretty cheap. Zero modification to the doors. You do have to cut the wires off and splice them to the new wires, but that's easy. Very good sound out of them too!
Hawk, You don't mention in your sig if you have the upgraded stereo (with the tweeters in the pillar I think) or if it is a quad cab or not. But fronts should be the same either way.
I don't know much of the speaker world but I do want to replace the two front speakers as one sounds awful. What do I need to know to replace these? I have an aftermarket Kenwood receiver, I'm not looking to share my music with the world, I just want something that sounds clear in the cab. Am I going to have to cut holes in the door panel or are there options to get something similar to the OEM speakers?
