- Replies 56
- Views 9k
WiscoRedkneck 16 posts
Mopar1973Man 9 posts
AH64ID 8 posts
LiveOak 7 posts
Should have added that my post was aimed mostly at extreme & severe weather circumstances. In most cases for most people those measures are not required, but if it is 30 below or worse outside wi
One thing I think i noticed in this thread, Double check the batteries! Part of the compression formula is speed. Cranking speed comes from voltage. Older batteries or poor connections,
You can have 4 batteries producing massive power. But if your cables, terminals, starter are all junk it won't matter how much power your batteries have if you can't deliver to the starter without hug
First off, Merry Christmas, second off I would like to say thank you to TFAORO for helping me get the truck running while off grid in -10 degrees Fahrenheit I had a 10 mile ride on a wheeler just to get a form of cell reception then for Tyler to respond quickly was awesome
So long short this is her first winter back on road 99 24 valve 5.9 4x4 auto with 320k on the clock basic mods and hybrid turbo, full frame off restoration... because of that I'm not ruling anything out yet.
The facts
Outside temp was -10 dropping to -14f blowing 20mph
Truck was plugged in on generator power for 6 hours tested for good voltage to find it present....
Oil weight 15w-40 dino 90 percent sure it mobil delvac
Use to run 10/30 but was advised against by parts store. I will get to this in a moment.
Fuel was treated and sample sitting on porch had not gelled
Truck was near impossible to start and once started oil pressure never came up I shut down after 6 seconds and tried again nothing.
Contacted Tyler removed injection pump wires(flipped dead man switch) and cranked
Started once more and after 6 seconds I had oil pressure and truck went to 3 cylinder high idle
Where I got confused is this
Block heater even at that outside temp should maintain a block temp that doesn't cause the truck to go into high idle imho.
Now I tested heater continuity and got 21.9 ohms a bit high but still in range.
My questions are is 5w-40 synthetic ok/good fit for the truck it's expensive and I don't want to be wasteful, and will that remedy some of the cold start issues.
And what would you guys recommend for checking block heater and the grid heaters, I think that about covers it.
I'm throwing in this video it's not my truck but my truck acted nearly identical just a little more difficult to start.
Edited by WiscoRedkneck
