Cold weather starting problems
First off, Merry Christmas,  second off I would like to say thank you to TFAORO for helping me get the truck running while off grid in -10 degrees Fahrenheit I had a 10 mile ride on a wheeler just to get a form of cell reception then for Tyler to respond quickly was awesome :thumb1:.
So long short this is her first winter back on road 99 24 valve 5.9 4x4 auto with 320k on the clock basic mods and hybrid turbo, full frame off restoration...  because of that I'm not ruling anything out yet.
The facts
Outside temp was -10 dropping to -14f blowing 20mph
Truck was plugged in on generator power for 6 hours tested for good voltage to find it present....
Oil weight 15w-40 dino 90 percent sure it mobil delvac
Use to run 10/30 but was advised against by parts store. I will get to this in a moment.
Fuel was treated and sample sitting on porch had not gelled
Truck was near impossible to start and once started oil pressure never came up I shut down after 6 seconds and tried again nothing.
Contacted Tyler removed injection pump wires(flipped dead man switch) and cranked
Started once more and after 6 seconds I had oil pressure and truck went to 3 cylinder high idle
Where I got confused is this
Block heater even at that outside temp should maintain a block temp that doesn't cause the truck to go into high idle imho.
Now I tested heater continuity and got 21.9 ohms a bit high but still in range.
My questions are is 5w-40 synthetic ok/good fit for the truck it's expensive and I don't want to be wasteful, and will that remedy some of the cold start issues.
And what would you guys recommend for checking block heater and the grid heaters, I think that about covers it.
I'm throwing in this video it's not my truck but my truck acted nearly identical just a little more difficult to start.
Edited by WiscoRedkneck
  • Replies 56
  • Views 11k
  • Should have added that my post was aimed mostly at extreme & severe weather circumstances.  In most cases for most people those measures are not required, but if it is 30 below or worse outside wi
  • One thing I think i noticed in this thread,   Double check the batteries!  Part of the compression formula is speed.  Cranking speed comes from voltage.  Older batteries or poor connections,
    You can have 4 batteries producing massive power. But if your cables, terminals, starter are all junk it won't matter how much power your batteries have if you can't deliver to the starter without hug
For the cost of a heater you can cover the cost difference of a good flowing synthetic for several years, and the oil will flow even if you're parked without electricity.
15w-40 synthetic will work very well for nearly everyone in the lower 48, and is a great summer oil too.
Should have added that my post was aimed mostly at extreme & severe weather circumstances.  In most cases for most people those measures are not required, but if it is 30 below or worse outside with high winds, these heaters may prove to be MUCH appreciated especially in terms of accelerated engine warm up and and associated cabin heat effectiveness for some of us older folks with tired old bones.  :)
Absoloutly. Getting much below -30°F is extreme weather and it takes more than just good fluids. At those temps lots of things have to be considered.
On a side note about cold starting, I never reinstalled my grid heater this winter as average winter temps here haven't needed it... well I am wondering if that was a bad choice. Since we got 9" of snow today, and it's still DUMPING, I'm driving the truck tomorrow. It will be low single digits when I leave for work and supposed to be close to 0° when I leave work.... it fires fast cold soaked to 12° without a grid heater so let's see what tomorrow brings.
Edited by AH64ID
These are extremes I have never seen and will never see. That I understand and cannot comment on. But I can identify with the tired older bones, I have a few.
It's -18° and dropping. I'd really like to see what happens without grids in the morning but I also need to get to work. I broke down and plugged it in. Block was 130° when it was plugged in so it should be quite toasty in the morning.
Hope you have the Winter fronts installed on the grill/radiator.  They will hold a good bit of what the block heater puts out allowing the entire underhood area to maintain some degree of warmth.  Also be mindful to either check under the hood or at least blow the horn good to chase out any animals that may make themselves a nice warm bed there for the night, especially if you have a cat.
Do you have a way to plug your truck in at work?
-6 here I've been bouncing around getting the parents furnace fixed, without grids plus my cardboard winter front I have not needed to plug in the truck and it starts great but I know I can't let it sit more than 4 hours at this temp without plugging in.
Also got some 5w-40 synthetic that will go in tomorrow Rotella I believe will update once done.  Sounds like it's only going to get colder here.
Looks like I may need to verify operation of my fuel heaters. -15° at the house and I had 6 psi. Low but not bad for the temp. After 2 miles it was -19° and pressure was 3. Turned around and got home when it dropped to 0 psi. I still had good rail pressure but didn't want to risk it.
I have winterized fuel and 2 300w grid heaters so I am fairly surprised I was having issues. It could be the sender, but???
Block heater had the coolant at 78° and intake manifold at 55°, which is in parameter for grids...when installed.
Is the fuel treated with power service as well or just winter blended fuel?
At those temps I have found that the fuel needs to be treated unless you have an article fox in tank heater or something along those lines....
Also take a water bottle and fill it with the fuel you have in the truck and set it on the porch if it's not gelled in the morning you are good.
I choose fill up sites carefully, always treat my fuel and always keep the water bottle of fuel outside to monitor tank conditions.
Best of luck and if the tank gelled up the factory heaters won't help you at all
My fuel sender does something similar.  The separation membrane inside the fuel isolator becomes stiff and initially will indicate low fuel pressure and no fuel pressure on cold days.  Once the engine compartment has had some time to warm up, the fuel isolator separator membrane becomes more flexible and eventually indicates accurate fuel pressure.  I tried changing mine out and the new fuel isolator did the same thing.  Now I just let the truck warm up a bit before a drive off and the fuel pressure gauge is usually indicating accurate.  I have my Air Dog set at about 18 psi.
-8 degree start up no grids been plugged in over night though.
Pay attention to the check gauges light 15w-40w dino took nearly 15 seconds to build pressure...
Cold start.mp4
I don't run an isolator but still wonder. The rail pressure was slow to build initially, when I had good pressure, but was hitting 20K when it should with 0 psi on the gauge.
I am headed home now to check the heaters and see what's up. I'm hoping it was an indication issue but either way I didn't want to be stranded at -19° even for a few minutes.
Cold start.mp4
The check engine light stayed on an uncomfortably long time.  Out of an abundance of caution, if you have not already, I would check to what if any codes latched.  A couple of the magnetic oil pan heaters would probably help eliminate such a long wait for oil pressure.
Well I found my problem. It appears the fuse holder for my additional fuel heater had faulty wiring that caused it to go open/closed/open and heat up to the point of bulging and melting. I can also see exposed wiring on the inlet side so I feel the issue was in the holder.
Before I found the failed fuse holder I was using and IR gun to check fuel temps while the truck was running. I was getting -12° in and out of the 1st heater inline (additional heater) and 11° out of the 2nd heater (the inlet is too hard to hit with an IR gun). The fuel psi gauge showed 0 psi but I was running fine, and before I would start the engine the pressure would go to 8 so I wasn't fulled plugged just partially.
Once I found and repaired the fuse holder the pressure went to 6-7 with the engine running almost instantly, within about 2 seconds. Fuel heaters work! The temp out of my final filter was up to 34° about 30 seconds after fixing the 1st heater. That's 23° warmer in less than a minute.
I wonder when the fuse blew/melted and how long I have been running on 1 heater. Prior to this morning the coldest I had seen here at home was -8°, and that's since living here. Since we are setting record cold temps I wonder if the winterized fuel isn't fully up to the task for unheated and exposed filters. I didn't see any broke down diesels but most of town was only -6° or so this morning and not the -19° I ran into.
Anyhow... morale of the story is trust your gauges and fuel heaters work!!!
Edited by AH64ID
@LiveOak I will throw a scanner on the truck but I'm confident that the switch to 5w-40 synthetic will resolve all my issues with oil pressure.
I have a magnet heater just never saw the need for it but I'm considering using it.
@AH64ID glad to hear you figured it out and yes the right heaters work wonders, but once tanks gell that's all she wrote.
My truck has two tank heaters one is 110v pad style, almost never used then I have the in tank artic fox which warms fuel with engine coolant.  Once my truck hits operating temperature the tank slowly climbs to around 80 degrees varies based on ambient temperature and fuel level.  I also have a shut off for it come summertime
Update, start up at 0 degrees with 5w-40 synthetic not plugged in with grid heaters fixed started 2ND try after cycling grids twice and I had oil pressure in 4 seconds
15w-40 dino is just not appropriate for our truck below 5 degrees IMHO, and 15 seconds for oil pressure is no good
